Hello,
I am trying to configure an edimax EW-7811Un, and I have gotten it to connect to my network. I can SSH into it over wifi, as well as access terminal from my PC. However, the Pi has no internet connectivity. Any ideas why it may be connecting to my wifi but not getting connected to the internet? I can successfully scan for networks, and all in-rang networks appear. In addition, iwconfig shows wlan0 present, and after turning on my adapter (after boot) using sudo ifup wlan0, I can even see that it is connected to the wifi via the pi. Furthermore, I can see its connectivity via my router. All configuration has been done over SSH via a wire connection. Running Raspbmc RC3.
Please help
I didn't find the right solution from the internet.
References:
https://www.raspberrypi.org/forums/view ... hp?t=31238Video production companyThank you
